Hello all,
I’m having problems using queues in a seq_item object.
Here’s the definition of my seq_item:
class axi4s_seq_item extends uvm_sequence_item;
rand bit [6:0] stream_len;
rand bit [32-1:0] stream_data [$];
rand int pre_wait;
`uvm_object_utils_begin(axi4s_seq_item)
`uvm_field_queue_int(stream_data, UVM_ALL_ON)
`uvm_field_int(stream_len, UVM_ALL_ON)
`uvm_field_int(pre_wait, UVM_ALL_ON)
`uvm_object_utils_end
function new(string name = "axi4s_seq_item");
super.new(name);
constraint size_c {
stream_data.size() == stream_len;
solve stream_len before stream_data;
constraint pre_wait_c {
pre_wait inside {[1:10]};
In my scoreboard, I get the transaction from the driver, so that I can update the reference model of the DUT. The run_phase of the scoreboard is:
super.run_phase(phase);
forever begin
// Get transaction from driver
driver_ap_fifo.get(txn);
// Update reference model
update_ref_model(txn);
task update_ref_model(axi4s_seq_item new_txn);
new_txn.print();
$display(new_txn.stream_data.size());
$display(new_txn.stream_len);
for(int idx = 0; idx < new_txn.stream_data.size(); idx++) begin
ref_model_ram.push_back(new_txn.stream_data[idx]);
ref_model_row_count++;
The problem I am facing is the following: the call to new_txn.print() shows the correct contents of the transaction, for instance:
Name Type Size Value
req axi4s_seq_item - @677
stream_data da(integral) 4 -
[0] integral 32 'hf9e96ed3
[1] integral 32 'h1f1f2ded
[2] integral 32 'hcf64120a
[3] integral 32 'hf0e95892
stream_len integral 7 'h4
pre_wait integral 32 'h9
begin_time time 64 0
depth int 32 'd2
parent sequence (name) string 3 seq
parent sequence (full name) string 31 uvm_test_top.env.agent.seqr.seq
sequencer string 27 uvm_test_top.env.agent.seqr
but then when I try to display steram_data.size() I always get a 0, and by extension the loop does no iterations. On the contrary, the stream_len field is correctly printed in the $display.
What am I missing?
Many thanks
Best regards
S
