Question regarding sv process::suspend
  5     class my_class;
  6         process m,n;
  7         task run();
  8             fork
  9                 begin : first_thread
 10                     m = process::self();
 11                     #10;
 12                     $display("first thread %0t",  $time);
 13                 end
 14
 15                 begin : second_thread
 16                     n = process::self();
 17                     #10;
 18                     #10;
 19                     $display("second thread %0t", $time);
 20                 end
 21
 22             join_none
 23
 24             wait(m!=null);
 25             m.await();
 26
 27             $display("time before suspend %0t", $time);
 28
 29             // wait for first thread to finish using await, then suspend second thread for 10ns
 30             n.suspend();
 31             #10;
 32             n.resume();
 33             // resume second thread , expecting to display 30?
 34             $display("time after resume   %0t", $time);
 35         endtask
 36     endclass
output:
first thread 10
time before suspend 10
second thread 20
time after resume 20
Hello there,
My question is that why second thread seems not suspended for 10?
My intent is to wait for first thread to finish ,and suspend sencond thread for 10 , and then resume second thread, then the second thread display should be happening @time 30, but it showed 20 instead, can anyone explain to me where I was wrong or what’s going under the hood?
In reply to Jeff_Li_90:
There are two issues.
First is you have a race condition. At the point when you suspend the second_thread, you don’t know if the 2nd #10 has been scheduled or not. If it has not, then you would get your expected results. But if it had been scheduled, the second issue is a Delay does not work like a timer. A Delay suspends the current process and schedules it to wake up at the appropriate time. The process will remain suspended if you have explicitly suspended it. It does not add time to the scheduled delay.
The process will remain suspended if you have explicitly suspended it. It does not add time to the scheduled delay. So calling process::suspend to Delay is like to call multiple times process::suspend to same thread, which will only be honored once. This is something new to me.
Thanks Dave for the explanation.
as Dave pointed out, there’s a race condition between when <second #10> and <n.suspend> scheduled. and clearly original output showed <second #10> scheduled first. I tried adding #0 to delay one to NBA region and it worked.
 16                     int nba, next_nba;
 17
 18                     n = process::self();
 19                     //repeat(20) begin
 20                     //    #1;
 21                     //end
 22                     #10;
 23
 24                     //next_nba++;
 25                     //nba <= next_nba;
 26                     //@(nba);
 27                     #0;    // delay to NBA region
 28                     #10;
 29                     $display("second thread %0t", $time);
 30                 end
