I have my USB UVC Agent declared as
class usb_agent #(int XCVR_SELECT_WIDTH) extends vc_agent;
// Inherits 'm_sequencer' which is of Type Parameter of parent class of vc_agent
super.run_phase(phase);
if( cfg.agent_cfg.is_active && cfg.agent_cfg.start_default_seq) begin
if( cfg.agent_cfg.agent_type inside { DEV,OTG_A_DEV,OTG_B_DEV } begin
dev_seq dev_seq_h = dev_seq::type_id::create("dev_seq");
dev_seq.start(m_sequencer);
join
I noticed that there is no objection raised within run_phase
Within class vc_agent and it’s super classes ( which is extended uvm_component ) I observe that there is no definition of run_phase.
Task run_phase within uvm_component calls another task run() which simply returns
Hence call to super.run_phase(phase) essentially calls run_phase defined in class uvm_component which doesn’t raise & drop an objection
Our test class overrides the pre_reset_phase , reset_phase and main_phase where it raises and drops an objection
As run_phase executes in parallel with sub-phases, does the sequence started in usb_agent’s run_phase continue execution till the objection is dropped in test’s main_phase ?
