Question on "pipelined access" in sequence - driver
The UVM cookbook on page 266 states following regarding the pipelined accesses:
" Pipelined Accesses
Pipelined accesses are primarily used to stress test the bus but they require a different approach in the sequence. A
pipelined sequence needs to have a seperate threads for generating the request sequence items and for handling the
response sequence items.
The generation loop will block on each finish_item() call until one of the threads in the driver completes a get() call.
Once the generation loop is unblocked it needs to generate a new item to have something for the next driver thread to
get(). Note that a new request sequence item needs to be generated on each iteration of the loop, if only one request item
handle is used then the driver will be attempting to execute its contents whilst the sequence is changing it.
In the example sequence, there is no response handling, the assumption is that checks on the data validity will be done by
a scoreboard. However, with the get() and put() driver implementation, there is a response FIFO in the sequence which
must be managed. In the example, the response_handler is enabled using the use_response_handler() method, and then
the response_handler function is called everytime a response is available, keeping the sequences response FIFO empty.
In this case the response handler keeps cound of the number of transactions to ensure that the sequence only exist when
the last transaction is complete.
Since the driver uses pipelined accesses, the sequence could modify a request item while the driver is still working on the previous sequence item. If only one handle is used for request item, driver could be executing its contents and sequence could be simultanesously modifying it. However, the code for pipelined sequence given below(reproduced from UVM cookbook) uses only one handle :
class mbus_pipelined_seq extends uvm_sequence #(mbus_seq_item);
  `uvm_object_utils(mbus_pipelined_seq)
  logic[31:0] addr[10]; // To save addresses
  int count; // To ensure that the sequence does not complete too early
  function new(string name = "mbus_pipelined_seq");
    super.new(name);
  task body;
    mbus_seq_item req = mbus_seq_item::type_id::create("req");
    use_response_handler(1);
    count = 0;
    for(int i=0; i<10; i++) begin
      start_item(req);
      assert(req.randomize() with {MREAD == 0; MOPCODE == SINGLE; MADDR inside {[32'h0010_0000:32'h001F_FFFC]};});
      addr[i] = req.MADDR;
      finish_item(req);
    foreach (addr[i]) begin
      start_item(req);
      req.MADDR = addr[i];
      req.MREAD = 1;
      finish_item(req);
    // Do not end the sequence until the last req item is complete
    wait(count == 20);
  endtask: body
  // This response_handler function is enabled to keep the sequence response
  // FIFO empty
  function void response_handler(uvm_sequence_item response);
    count++;
  endfunction: response_handler
endclass: mbus_pipelined_seq
Here the create function is not put inside the loop but is outside loop. So there will be only one handle for request item. Is this an error in the code given in the UVM cookbook. Can someone explain please
regards,
-sunil puranik
