I have a question on net declaration as follows :
If I declare a wire with following declaration,
wire integer x; or declare a port with inout wire integer y , I am getting syntax error with VCS simulator. Now the System verilog LRM gives following format for net declaration:
net_declaration12 ::= // from A.2.1.3
net_type [ drive_strength | charge_strength ] [ vectored | scalared ]
data_type_or_implicit [ delay3 ] list_of_net_decl_assignments ;
Now according to LRM, net_type can be supply0 | supply1 | tri | triand | trior | trireg | tri0 | tri1 | uwire | wire | wand | wor
and the data_type_or_implicit can be : data_type | implicit_data_type.
The data_type ::= integer_vector_type [ signing ] { packed_dimension }
| integer_atom_type [ signing ]
| non_integer_type
| struct_union [ packed [ signing ] ] { struct_union_member { struct_union_member } }
{ packed_dimension }13
| enum [ enum_base_type ] { enum_name_declaration { , enum_name_declaration } }
| string
| chandle
| virtual [ interface ] interface_identifier [ parameter_value_assignment ] [ . modport_identifier ]
| [ class_scope | package_scope ] type_identifier { packed_dimension }
| class_type
| event
| ps_covergroup_identifier
| type_reference14
Implicit_data_type ::= [ signing ] { packed_dimension }
Now based on above, it I write
wire integer x, it should be syntactically correct, since
wire is a legal net_type and integer is legal data_type.
Can someone explain if my understanding is correct and why should I get error for above declaration.
Also can someone explain when we need to use reference type when declaring module ports? What is the significance of reference keyword for module ports?
-sunil
