The SYSTEM VERILOG ASSERTIONS HANDBOOK, 4th Edition states following on page no. 36:
Do not use first_match function in a sequence that is an antecedent that has goto repetition operator unless that sequence has other expressions which are multi-ranged.
Thus a ##1 b[->1] |-> c; //first_match is not needed here because once b==1, there could not be another thread of !b.
The book also states on page no. 37 that for non-consecutive repetition operator, in an antecedent, we NEED TO USE first_match function:
a ##1 b[=1]##1 c |-> d; is equivalent to
a ##1 !b[*0:$] ##1 b ##1 !b[*0:$] ##1 c |-> d;
// !b[*0:$] ##1 c can cause mutliple threads.
(can someone explain why this causes multiple threads?)
Now above statement is equivalent to !b[*0] ##1 c or !b[*1] ##1 c or !b[*2] ## 1 c … and so on. ( !b ## 1 c or !b ##1 !b ## 1 c …)
Are the multiple threads caused by or operator in the above expression?
In that case even for goto operator example given above - a ##1 b[->1] |-> c;
There will be multiple threads as b[->1] is equivalent to !b[*0:$] ##1 b; Why does this not cause multiple threads (because of repetition of !b)
Can someone explain this in the detail.
regards,
-sunil puranik
In reply to puranik.sunil@tcs.com:
[Ben]
!b[*
a ##1 !b[*0:$] ##1 b ##1 !b[*0:$] ##1 c |-> d; // correct, expanded to:
(a ##1 !b[*0] ##1 b ##1 !b[*0] ##1 c) or
(a ##1 !b[*1] ##1 b ##1 !b[*0] ##1 c) or
(a ##1 !b[*n] ##1 b ##1 !b[*0] ##1 c) or
(a ##1 !b[*0] ##1 b ##1 !b[*1] ##1 c) or
(a ##1 !b[*0] ##1 b ##1 !b[*2] ##1 c) or
(a ##1 !b[*0] ##1 b ##1 !b[*n] ##1 c) or
(a ##1 !b[*1] ##1 b ##1 !b[*1] ##1 c) or
(a ##1 !b[*1] ##1 b ##1 !b[*2] ##1 c) or
(a ##1 !b[*1] ##1 b ##1 !b[*n] ##1 c) or
(a ##1 !b[*n] ##1 b ##1 !b[*1] ##1 c) or
(a ##1 !b[*n] ##1 b ##1 !b[*2] ##1 c) or
(a ##1 !b[*n] ##1 b ##1 !b[*n] ##1 c) |-> d
// There are lots of other possible matches after b==1
// and without a first_match() they all have to be tested
Yes, as explained above
a ##1 b[->1] |-> c // equivalent to
a ##1 !b[*0] ##1 b |-> c; // equivalent to
a ##1 !b[*1] ##1 b or
a ##1 !b[*2] ##1 b or
a ##1 !b[*n] ##1 b |-> c;
// If the tread (a ##1 !b[*1] ##1 b ) is a match with b==1 then
// All the other threads are false
// a ##1 !b[*1] ##1 b means a==1 ##1 b==0 ##1 b==1 // Then
// a ##1 !b[*2] ##1 b // is a no match because we saw the sequence b==0 ##1 b==1
// thus b==0 ##1 b==0 is a no match, and so are all of the other sequences.
// The simulator does not test all the other possibilities since once you find one match
// Alll of the others are not a match.
-sunil puranik[/quote]
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
Ben Cohen on LinkedIn: Road map to start with verification: SV, SVA , UVM and TB
