Write at least 4 System Verilog Assertions for validating a 4bit bidirectional shift register
with active low synchronous reset.
In reply to Chandrika Ummidi:
Sounds like a good interview Q or a classroom quiz, please attempt answers and seek help if you are stuck.
Good luck
- Assert that the shift register initializes to all zeroes after reset:
property reset_initialization;
reg [3:0] shift_register;
@(posedge clk) disable iff (!reset_n)
(shift_register == 4'b0000);
- Assert that the data shifts correctly to the left when the shift_left signal is active:
property shift_left_operation;
(shift_left && !shift_right) |-> (shift_register == {shift_register[2:0], 1'b0});
Same as 2nd for right_shift_operation
Assert that the shift register maintains its value when neither shift_left nor shift_right is active:
property no_shift_operation;
(!shift_left && !shift_right) |-> (shift_register == shift_register);
Taking clues from what @verif_guy12 mentioned before, is this the correct implementation of properties for the below 5 scenarios.
- At reset the shift_register initializes to '0.
property reset_init;
@(negedge reset_n) (shift_reg == 4h'0);
- Value is maintained when neither shift_left or shift_right is set
property no_shift_op;
(!shift_left && !shift_right) |=> $stable(shift_reg);
- Shift left
property shift_left_op;
(shift_left && !shift_right) |=> shift_reg == ($past(shift_reg) << 1);
- Shift right
property shift_right_op;
(!shift_left && shift_right) |=> shift_reg == ($past(shift_reg) >> 1);
- Both shift_left and shift_right cannot be active simultaneously
property no_simultaneous_shift_op;
!(shift_left && shift_right)
Since the op mentions active low synchronous reset, the disable iff ( !reset_n ) should be removed.
@(posedge clk) !reset_n |=> shift_register == 4'b0000 ;
For scenarios 2-5 , boolean_expression ‘reset_n && …’ should be added in the antecedent.
For example:
// 2. Value is maintained when neither shift_left or shift_right is set
@(posedge clk) ( reset_n && !shift_left && !shift_right ) |=> $stable(shift_reg);
Similarly ‘reset_n &&’ should be added for scenarios 3-5
