How does the below array will work ??
byte a[*][$];
can anyone explain with example, will helps me to analyse?
Thank you,
byte a[*][$];
Thank you,
In reply to Lakshman4178:
It would try to understand 2-dimensions before tackling 3.
https://verificationacademy.com/forums/ovm/multi-dimensional-dynamic-arrays
P.S. Do not use wildcard [*] index for associative arrays. They are very restrictive (i.e. cannot be used in a foreach loop. Use [int] instead.
