Identifiers defined inside an unnamed block should not be visible outside that block according to the LRM. Consider a tool bug if you are allowed to access it. Unfortunately, some tool bugs become undocumented features of the language that all tools implement. This may be one of the cases where the unnamed block is stripped away for being superfluous. If you add a variable declaration inside that unnamed block, then the a1 block becomes inaccessible.
An unnamed block creates a new hierarchy scope only if it directly contains a block item declaration, such as a variable declaration or a type declaration.
This peculiarity arose because Verilog 1364 did not allow declarations in unnamed blocks.
Thanks Dave, In the above code i am able to access variable āiā using a.i notation. So looks like as long as we are not having any variable declared inside un-named block named sub-blocks can be accessed directly
