Question about argument passing behavior in fork join_none block
Hi All,
I am confused at the sim result of the following fork…join_none code
 fork: receive_fork
  receive(1);
  receive(2);
 join_none
  #30ns;
  $display("%0t: Done", $time);
task receive(int index);
  $display("entering receive, index=%0d",index);
  #(index * 10ns);
  $display("%0t: Receive is done for index = %0d", $time, index);
Sim result
entering receive, index=1
entering receive, index=2
10: Receive is done for index = 2
20: Receive is done for index = 2
30: Done
I wonder for thread receive(1), why when argument “index” is used in the first display syntax and #(index*10ns) expression, “index” has the desired value of 1, but inside the second display syntax, the value of “index” becomes 2?
I understand that for the following example,
for(int j=0;i<3;j++)
    $write(j);
  join_none
all three $write result will be j=3 since the spawned $write(j) thread won’t execute until the for loop is exited. But for my example, when executing
  #(index * 10ns);
the value of “index” is already 1, I am very confused why “index” became 2 when executing
Thanks in advance for your help!
In reply to peterjin:
Because you declared the task receive() with a static lifetime (the implicit default lifetime). That means there is only one argument index for all calls to receive. Change the declaration to
task automatic receive(int index);
Thanks for the explanation, that solved my confusions!
Hao
