i am using questasim 10.2C and it is showing covergroup details for System verilog based testbench environment but it is not showing covergroup details for uvm based testbench environment. can you give some solution for the same?
In reply to piyushpatel123:
Your question does not provide enough information. I guess you forget to change the option of covergroups in UVM.
covergroup cg_uvm;
option.per_instance = 1;
// code
endgroup
In reply to An Pham:
`ifndef GUARD_MONITOR_AHB_MASTER_IP
`define GUARD_MONITOR_AHB_MASTER_IP
`include "uvm_macros.svh"
import uvm_pkg::*;
//`include "SEQUENCE_ITEM_AHB_MASTER.sv"
class MONITOR_AHB_MASTER_IP extends uvm_monitor;
`uvm_component_utils(MONITOR_AHB_MASTER_IP)
//uvm_analysis_port#(SEQUENCE_ITEM_AHB_MASTER)Rcvr2Sb_port;
//uvm_analysis_port#(SEQUENCE_ITEM_AHB_MASTER)Rcvr2cover_m;
virtual INTERFACE_AHB_MASTER inf5;
//SEQUENCE_ITEM_AHB_MASTER pkt5;
function new(string name = "MONITOR_AHB_MASTER_IP",uvm_component parent);
super.new(name,parent);
//super.build_phase();
//Rcvr2Sb_port = new("Rcvr2Sb_port",this);
//Rcvr2cover_m = new("Rcvr2cover_m",this);
//pkt5 = SEQUENCE_ITEM_AHB_MASTER :: type_id :: create("pkt5",this);
if(!uvm_config_db#(virtual INTERFACE_AHB_MASTER)::get(this,"","inf_M",inf5))
`uvm_error("","uvm_config_db::get failed")
covergroup ahb_m_cg @(negedge inf5.HCLK);
BURST:coverpoint inf5.HBURST;
ADDR:coverpoint inf5.HADDR; //we can sample using condition using *** ADDR:coverpoint inf5.HADDR iff(condition) ***;
WDATA:coverpoint inf5.HWDATA;
SIZE:coverpoint inf5.HSIZE;
TRANS:coverpoint inf5.HTRANS{ bins idle_nonseq = (2'b00 => 2'b10);
bins nonseq[] = (2'b10 => 2'b11,2'b10,2'b00);
bins seq[] = (2'b11 => 2'b00,2'b10);
bins seq_busy_seq = (2'b11 => 2'b01 => 2'b11);
bins seq_busy_idle = (2'b11 => 2'b01 => 2'b00);}
WRITE:coverpoint inf5.HWRITE;
RESP:coverpoint inf5.HRESP{ bins okay_error = (2'b00 => 2'b01 => 2'b01);
bins okay_retry = (2'b00 => 2'b10 => 2'b10);
bins okay_split = (2'b00 => 2'b11 => 2'b11);}
READY:coverpoint inf5.HREADY{ bins resp = (1'b1 => 1'b0 => 1'b1 => 1'b1);
bins not_ready = (1'b1 => 1'b0[*2:5] => 1'b1);}
RDATA:coverpoint inf5.HRDATA;
PROT:coverpoint inf5.HPROT{ bins opcode_data = (4'bxxx0 => 4'bxxx1);
bins user_previ = (4'bxx0x => 4'bxx1x);
bins buffer_nonbuffer = (4'bx0xx => 4'bx1xx);
bins cach_noncach = (4'b0xxx => 4'b1xxx);} //IMS_AHB_M_COV_CP_PROT_0001_1
LOCK:coverpoint inf5.HLOCKx{bins lock_unlock = (1'b0 => 1'b1 => 1'b0);} //IMS_AHB_MASTER_COV_CP_LOCK_0003_1
cross BURST, ADDR, WDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_BURST_0002_2
cross BURST, ADDR, RDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_BURST_0002_2
cross SIZE, ADDR, WDATA; //IMS_AHB_MASTER_COV_CRS_SIZE_0004_2 //IMS_AHB_MASTER_COV_CRS_ADDR_0007_2 //IMS_AHB_MASTER_COV_CRS_WDATA_0008_2
cross SIZE, ADDR, RDATA; //IMS_AHB_MASTER_COV_CRS_SIZE_0004_2 //IMS_AHB_MASTER_COV_CRS_ADDR_0007_2 //IMS_AHB_SLAVE_COV_CRS_RDATA_0004_2
cross TRANS, BURST;
cross TRANS, READY; //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross TRANS, WRITE;
cross WRITE, BURST; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2
cross WRITE, TRANS; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2
cross WRITE, WDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2 //IMS_AHB_MASTER_COV_CRS_WDATA_0008_2
cross WRITE, RDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2 //IMS_AHB_SLAVE_COV_CRS_RDATA_0004_2
cross WRITE, ADDR; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2 ////IMS_AHB_MASTER_COV_CRS_ADDR_0007_2
cross WRITE, LOCK; //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2 //IMS_AHB_MASTER_COV_CRS_LOCK_0003_2
cross WRITE, READY {illegal_bins W0R0 = binsof(WRITE) intersect {0} && binsof(READY) intersect {0};} //IMS_AHB_MASTER_COV_CRS_WRITE_READ_0006_2 //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross ADDR, RESP; //IMS_AHB_MASTER_COV_CRS_ADDR_0007_2
cross WDATA, RESP, SIZE; //IMS_AHB_MASTER_COV_CRS_WDATA_0008_2
cross WDATA, READY, SIZE; //IMS_AHB_MASTER_COV_CRS_WDATA_0008_2 //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross RESP, READY; //IMS_AHB_SLAVE_COV_CRS_RESP_0001_2 //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross RESP, BURST; //IMS_AHB_SLAVE_COV_CRS_RESP_0001_2
cross RESP, TRANS; //IMS_AHB_SLAVE_COV_CRS_RESP_0001_2
cross READY, RDATA, SIZE; //IMS_AHB_SLAVE_COV_CRS_READY_0002_2 //IMS_AHB_SLAVE_COV_CRS_RDATA_0004_2
cross READY, BURST; //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross READY, ADDR; //IMS_AHB_SLAVE_COV_CRS_READY_0002_2
cross RDATA, RESP, SIZE; //IMS_AHB_SLAVE_COV_CRS_RDATA_0004_2
cross PROT, ADDR; //IMS_AHB_MASTER_COV_CRS_PROT_0001_2
cross PROT, WDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_PROT_0001_2
cross PROT, RDATA, SIZE; //IMS_AHB_MASTER_COV_CRS_PROT_0001_2
endgroup
//super.run_phase();
forever
//Rcvr2Sb_port.write(pkt5);
/*pkt5.HADDR <= inf5.HADDR;
pkt5.HWDATA <= inf5.HWDATA;
pkt5.HBURST <= inf5.HBURST;
pkt5.HSIZE <= inf5.HSIZE;
pkt5.HTRANS <= inf5.HTRANS;
pkt5.HWRITE <= inf5.HWRITE;
pkt5.HBUSREQx <= inf5.HBUSREQx;
pkt5.HPROT <= inf5.HPROT;
pkt5.HLOCKx <= inf5.HLOCKx;
Rcvr2cover_m.write(pkt5);*/
/*$display("=============================================================================");
$display("------- in Monitor Run Phase Master input side --------");
$display(" ");
$display("Add = %h -- TRANS = %b -- SIZE = %b -- BURST = %b -- WDATA = %h -- WRITE = %b -- READY = %b", inf5.HADDR, inf5.HTRANS, inf5.HSIZE, inf5.HBURST, inf5.HWDATA, inf5.HWRITE, inf5.HREADY);
$display(" ");
$display("=============================================================================");*/
if(inf5.HGRANTx && inf5.HRESETn)
ahb_m_cg.sample();
`endif
this is my code for the monitor and inside it i have mentioned covergroup but still it is not showing covergroup details in covergroup tab for particular uvm based test bench however it is showing correctly for SV based test bench.
You never constructed your covergroup in the class constructor.
is there any need to construct the constructor for embedded covergroup?
i have seen many examples which has embedded covergroup and without constructor.
You are required to construct a covergroup
An embedded covergroup variable may only be assigned in the new method. An embedded coverage group can be explicitly instantiated in the new method. If it is not, then the coverage group is not created and no data will be sampled.
is there any limit for number of bits which we can sample? because here for the above code when i am sampling HWDATA of size 1024 Bits questasim giving error “Fatal: (SIGSEGV) Bad handle or reference.”
Fatal error reported during simulation. Cannot run ‘fcover’ command. Please look above output for the fatal error message(s).
thanks you…i have solved it but when i sample HWDATA of 1024 bits i am getting this error
can you give me solution of it?
