PSL PWM Duty Cycle
Sorry if this is OT.
This must be an issue that comes up a lot - I am trying to verify the width (in clock cycles) of a pulse, where this width is defined in a register. i.e. Is not constant.
asrt_duty_pwm1 : assert always {~pwm1_dig;pwm1_dig} |-> {pwm1_dig[duty1_dff];~pwm1_dig[(1000-duty1_dff)]} ;
Unfortunately, this does not work, and I get the error:
  asrt_duty_pwm1 : assert always {~pwm1_dig;pwm1_dig} |-> {pwm1_dig[*duty1_dff];~pwm1_dig[*(1000-duty1_dff)]} ;
ncvlog: *E,NOTPAR (/design/proj/sp34/users/steven.dennis_sp34a_175/digital/modules/sp34_dpwm.pslvlog,8|81): Illegal operand for constant expression [4(IEEE)].
Can somebody suggest a workaround? Would I have the same issue using SVA?
Steven
In reply to moogyd:
The following is a much easier solution for you. Not everything needs to be concurrent assertions; you can use supporting logic, as shown here.
	// verify the width (in clock cycles) of a pulse, where this width is defined in a register.
	bit clk, pw;
	int count, pw_limit=5;
	initial forever #10 clk=!clk;
	always_ff  @(posedge clk)  begin
	  if($fell(pw)) count <= 1;
	  if($rose(pw)) assert (count == pw_limit)
                 $display("PASS, @%t count=%d", $time, count);
	    else $display("pw error, @%t count=%d", $time, count);
	  else count += 1;
     repeat(200) begin
       @(posedge clk);
       if (!randomize(pw)  with
          {pw dist {0 :=6, 1 := 1};
       $finish;
// SIm results
# pw error, @                3330 count=          4
# PASS, @                3450 count=          5
# pw error, @                3490 count=          1
# pw error, @                3530 count=          1
# pw error, @                3570 count=          1
# pw error, @                3610 count=          1
# pw error, @                3930 count=         15
# ** Note: $finish    : pw.sv(24)
#    Time: 3990 ns  Iteration: 1  Instance: /top
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
If you need a SVA assertion, instead of just supporting code with an immediate assertion (a better approach, BTY), yoiu can do this.
	bit clk, pw;
	int count, pw_limit=1;
          if($rose(pw)) ap_1: assert (count == pw_limit) $display("PASS, @%t count=%d", $time, count);
		else count += 1;
    // concurrent assertion  <<<<--------------------------------------------
    property p_pw;
    	int v_count;
    	($fell(pw), v_count = 0) |=>
    		first_match((1, v_count+=1)[*1:$] ##0 $rose(pw)) ##0 v_count == pw_limit;
    ap_pw: assert property(p_pw)
    		else $display("pw error @%t", $time);
     repeat(200) begin
       @(posedge clk);
       #2 if (!randomize(pw)  with
          // { pw dist {[1:4] :=1, [5:7] := 2};
       	 { pw dist {0 :=1, 1 := 1};
       $finish;
// Sim results
pw error, @                 130 count=          6
# PASS, @                 170 count=          1
# pw error, @                 230 count=          2
# pw error @                 230
# pw error, @                 290 count=          2
# pw error @                 290
# PASS, @                 330 count=          1
# PASS, @                 370 count=          1
# pw error, @                 490 count=          3
# pw error @                 490
Thanks a lot Ben - that’s perfect.
BTW - the assertion solution means I don’t have top update the RTL.
Steven
p.s. I tried to mark both you posts as a solution, but this isn’t allowed.
In reply to moogyd:
Steven,
The best way to avoid changes to your RTL is to use checkers. From my book,
Checkers have numerous advantages over modules and interfaces: they are race-free, they allow sequences and properties as arguments, their invocation syntax is more intuitive and concise, they may be instantiated both inside and outside procedural code, they may infer their clock and reset contexts, they have free variables, etc.46 Checkers are ignored by synthesis tools; this allows assertions to be embedded in RTL code, but without the concerns associated with improper synthesis of supporting code. It also allows for external modifications of code within the checkers without changing any time-stamp of RTL code.
46 From “ SystemVerilog Checkers: Key Building Blocks for Verification IP”,
Laurence Bisht, Dmitry Korchemny, Erik Seligman Intel Corporation http://events.dvcon.org/2012/proceedings/papers/01P_1.pdf
Below is complete code with the use of a SV checker.
checker rtl_chk(input bit clk, pw,
                      int pw_limit);
  int count;
    else count += 1;
  property p_pw;
	int v_count;
endchecker
module rtl;
	bit clk, pw;
	int pw_limit=1;
	rtl_chk rtl_chk1(clk, pw, pw_limit);
     repeat(200) begin
       @(posedge clk);
       $finish;
// Sim results
PASS, @                  30 count=          1
# PASS, @                  90 count=          1
# pw error @                 190
# pw error, @                 190 count=          4
# PASS, @                 290 count=          1
# pw error @                 430
