Property specification using a generate block
property is_x;
  @ (clk) disable iff (rst_n !== 1)
    ($isunknown(data) == 0);
endproperty: is_x
assert property (is_x) else `uvm_fatal ("", "data is unknown")
Question:
If data goes from 1 bit to 16 bits (data[15:0]), how do I use a generate statement to rewrite the property/assertion shown above to keep the code concise?
Thank You!
In reply to new_to_uvm:
The built-in $isunknown can handle bit-vector and hence the code you’ve would work for 16 bits without any change.
Srini
www.go2uvm.org
In reply to Srini @ CVCblr.com:
Thank You Srini!
