Hi Friends,
In below example,While reading queue using either foreach and for loop,it won’t iterate through all the queue element, where as when i write queue reading logic inside repeat construct either with the hard coded value or queue_Size ,it reads properly. but not with foreach and for construct.
module queue_of_class_ex;
class packet;
static int UID =0;
rand bit [2:0] temp1;
rand byte temp2;
function new;
UID++;
function void print ();
$display("UID=%0d,temp1=%0d,temp2=%0d",UID,temp1,temp2);
endfunction:print
packet txnh,txn_read;
initial
//declare queue of packet type
packet txn_que[$];
//txnh = new;
repeat(5)
txnh = new;
assert(txnh.randomize())
//txnh.print();
$error("Randomization failed");
//Pushing randomized packet into queue to store it
$display("Pushing Packet with ID=%0d into queue",txnh.UID);
txn_que.push_back(txnh);
$display("Before Reading Packet from queue size=%0d",txn_que.size);
//foreach(txn_que[que_size])
for(int que_size =0;que_size < txn_que.size;que_size--)
txn_read = txn_que.pop_front();
txn_read.print();
// here after reading it through either foreach and for loop it
// still shows the queue size 2 instead 0.
$display("After reading,queue size become %0d",txn_que.size);
Thanks.
