Hi All,
In following code, K will be disappeared when leaving begin end block. Is there any way to show or prove that K is really disappeared during simulation?
for (int j=0; j<3; j++) begin
automatic int k;
Thank you
Hi All,
automatic int k;
Thank you
In reply to peter:
No.
In reply to peter:
The value of k declared in class is never updated by the function’s automatic variable. Does this help you note that the value disappeared?
class automaticVar;
int k;
function dissappear;
automatic int k;
for(k=0;k<10;k++) begin
$display("value of k is %0d",k);
function reuse;
$display("New value of k is %0d",k);
automaticVar av1 = new();
av1.dissappear();
av1.reuse();
