Hi All,
I tried to write a reactive sequence that constantly monitors a pin on the output of the DUT and take some sequence of actions when it sees one. However, I cannot figure out how to push the sequence into the background and make it always observe the pin (kind of like a monitor). Here is the simplified version of what I have :
// Inside the driver
super.run_phase(phase);
forever begin
my_item m_dummy;
my_item m_tx_item;
m_tx_item = new("m_tx_item");
@(vif.clk);
seq_item_port.get_next_item(m_dummy);
m_tx_item.signal = vif.signal;
m_tx_item.set_id_info(m_dummy);
seq_item_port.item_done(m_tx_item);
endtask : run_phase
// Inside the sequence
virtual task body();
my_item m_rx_item;
my_item m_dummy;
m_dummy = new("m_dummy");
forever begin
start_item(m_dummy);
finish_item(m_dummy);
get_response(m_rx_item);
if(m_rx_item.signal) begin
// Do some tasks
break;
join_none
wait fork;
endtask : body
// Starting of the sequence
my_sequence m_seq;
m_seq = new("m_sequence");
m_seq.start(env.my_agent.my_sqr);
The above code does not do what I want it to do. Looks like it is just running infinitely and blocking other sequences from running (I’m not sure how this is happening as I have exclusive sequencer created just for this purpose)
I’ve tried placing the forever loop around the code that starts the sequence instead of in the sequence itself, but this was leading to a SEQREQZMB error.
The above sequence does not drive anything as of now (hence dummy items) but will drive something in the future and hence to keep to simple, I’m writing a reactive sequence.
I’d appreciate if anyone can give me a better suggestion.
Thank you
