Problem in using shift operator
I encountered a problem in using the shift operator. In the example below, ser_data is one bit wide and data_reg, input_data, temp_reg are 60 bits wide. This is an example of serializing data. Data is first read in data_reg. It is then shifted and sent out via ser_data.
// Read data @ encoder clock
always_ff @(posedge clk_en)
	if (reset_n)
		data_reg <= input_data;
// Write data to output @ 60*encoder clock
always_ff @(clk_ser)
	if (reset_n)
	    ser_data <= data_reg[59];
	    data_reg <= data_reg<< 1; // **THIS DOESN’T WORK: data_reg is always 0.**
For debugging purposes, I used: temp_reg <= data_reg <<1
Now I can see the shifted data in temp_reg. Why doesn’t “data_reg <= data_reg<< 1” work ?
You are making assignments to data_reg in two different always_ff blocks. Perhaps you have a race condition.
Dave,
Actually, 1800-2009 section 9.2.2.4 Sequential logic always_ff procedure says
"Variables on the left-hand side of assignments within an always_ff procedure,
including variables from the contents of a called function, shall not be written to by any other process.
Thus, the
“data_reg <= data_reg<< 1; // THIS DOESN’T WORK: data_reg is always 0.” is illegal.
Ben Cohen, Design and verification expert (310) 997-2187
  • SystemVerilog Assertions Handbook, 3rd Edition, 2013 ISBN 0-9705394-3-6
  • Component Design by Example, 2001 ISBN 0-9705394-0-1
@ben, dave - thank you
