Is there a way to print a UVM TB topology is much detailed way than the already present “print_topology”?
My intent is to display (a) all components instantiated (b) TLM port connections between components for starters.
(a) Assuming all the components are created through the factory, you can use factory.print() which returns information about the classes registered with the factory and any overrides. There are also debug_create_by_type and debug_create_by_name
(b) For TLM ports you can use get_connected_to (port’s fanout network) and get_provided_to (port’s fanin network)
The following uvm cookbook section has more detailed information Builtin Debug
