pre randomize and post randomize will work in which phase()???
IN START OF SIMULATION
is that true??
is that true??
In reply to ram999:
No, this is not true. It will be executed in the run_phase().
No, this is not true. The functions pre_randomize() and post_randomize() are part of the SystemVerilog LRM and not part of the UVM. The pre_randomize() and post_randomize() functions are called as part of the randomize() function of a class. pre_randomize() will be called prior to the constraint solver, and post_randomize() will be called after the constraint solver.
While it is true that randomize() is mainly called in the run_phase(), this is not always the case if you are randomizing configuration objects.
Thanks a lot…
