Power aware verification
In low power verification, we typically deal with power-up and power-down sequences for power-gated IPs.
During the power-up sequence, the order I’ve often seen is:
Power ON → Reset → State Restore → Isolation Enable De-asserted → Clock Enable
However, I have a concern:
Without the clock being active, how are the restored values (from state retention logic) updated inside the IP?
Is this power-up sequence correct, or should the clock be enabled earlier in order to properly latch the restored values?
It depends on how the State restore gets implemented. Many times it is done asynchronously.
