Possible alternative to multiple $test$plusargs
Hi All,
Consider the following code
    if ( $test$plusargs ("ARG1") || $test$plusargs ("ARG2") || $test$plusargs ("ARG3") || $test$plusargs ("ARG4") || ... || $test$plusargs ("ARG10") )
     // Procedural code
If there are numerous run-time args. that need to be checked, is there a possible solution similar to inside operator ?
    <Some Logic here>
    if ( <Logic> inside { "ARG1" , "ARG2" , "ARG3" , "ARG4" .. , "ARG10" } )
     // Procedural code
The UVM class uvm_cmdline_processor has a function get_arg_matches() that returns a queue of all the +args on the command line that match a regular expression. That expression could be a list of all the alternative switches you want to match.
I know that you’ve previously asked questions about UVM. However, even if your testbench isn’t based on UVM, you can utilize this class independently to achieve the functionality you’re looking for.
Thanks Dave. Tried an example for the same.
An interesting observation is if condition is true with run-time arg. as +ARG1232 for $test$plusargs whereas command line processor correctly identifies the difference
