Popping Queue elements as sequence_expr
I was trying the following code ::
 `ifdef M1
   always #5 clk1 = !clk1;
   always #6 clk2 = !clk2;
 `elsif M2
   always #6 clk1 = !clk1;
   always #5 clk2 = !clk2;
 `elsif M3
 `endif
   bit[2:0] value_q[$] ;
   always@(posedge clk1) value_q.push_back($urandom());
   property queue_pop;
     @(posedge clk2) value_q.pop_back();
   aq_pop:assert property( queue_pop ) $display("T:%0t Pass",$time); else  $display("T:%0t Fails",$time);
  initial #50 $finish();
To my surprise I observe compilation error
Error-[ETTNATE] Invalid type in temporal expression
Why is ‘value_q.pop_back()’ not considered a valid sequence expression ?
pop_back() is a function call.
This should work
(1, v=value_q.pop_back()) ##0 v==1
This could also be a tool issue.
In the past I had issues with associative arrays.
Hi Ben,
Using
   property queue_pop;
      int loc;
     @(posedge clk2) (1,loc=value_q.pop_back()) ##0 loc;
I am still observing compilation issues with the following msg
Tool1 ::
** Error: Queue_pop_as_Seq_Expr.sv(23): The method ‘pop_back’ is not allowed in assertions as it has side effects.
Tool2 ::
Expressions involving real, realtime, string, event and dynamic
SystemVerilog types including virtual interface references are not allowed
in local variable assignments in properties and sequences.
I checked SV LRM 2023 for this
16.6 Boolean expressions
Elements of dynamic arrays, queues, and associative arrays that are sampled for assertion expression
evaluation may get removed from the array or the array may get resized before the assertion
expression is evaluated. These specific array elements sampled for assertion expression evaluation
shall continue to exist within the scope of the assertion until the assertion expression evaluation
completes.
Sequence match items with a local variable as the variable_lvalue may use the C assignment,
increment, and decrement operators. Otherwise, evaluation of an expression shall not have any side
effects (e.g., the increment and decrement operators are not allowed).
LRM further mentions the following example
bit a;
integer b;
byte q[$];
property p1;
 $rose(a) |-> q[0];
property p2;
 integer l_b;
 ($rose(a), l_b = b) |-> ##[3:10] q[l_b];
So this does tell me that using Queue element as sequence_expr is legal (provided they are of integral type)
One solution is to return value_q.pop_back() from a subroutine called on match of a seq_expr
The following worked with 2 tools, but gave me an error with another one.
module m(input bit valid, clk,
               bit[31:0]  addr);
  // There is a valid,addr protocol similar to AXI.
  // I want to write an assumption that last 16 valid addresses(with valid=1) has to be unique .
    int mem_aarray[*]; // associative array (AA) to be used by property
    //bit [31:0] raadata;  // data read from AA
    bit  mem_aarray_exists;  // exists at specified address
    // assign mem_aarray_exists  = mem_aarray.exists(addr);
    function automatic void f0(); mem_aarray.delete; endfunction
    function automatic bit f1(int addr);
       return mem_aarray.exists(addr);
    property m_valid_addr;
      bit v_err=0;
        @(posedge clk) ($rose(valid) , f0()) |->
      ((valid, v_err=f1(addr)) ##0 !v_err)[*16]; // it should not exist
  am_valid_addr: assume property(m_valid_addr);
  property m_valid_addr2; // line 22
  bit v_err=0;
  ((valid, v_err=mem_aarray.exists(addr)) ##0 !v_err)[*16]; // it should not exist
am_valid_addr2: assume property(m_valid_addr2);
//Invalid type in local variable assign
testbench.sv, 22
m, "mem_aarray.exists(addr)"
Note: Using an external user-defined function call worked.
My paper addresses the issues you brought up.
SVA PAPER: DYNAMIC DATA STRUCTURES IN ASSERTIONS
The integration of dynamic data structures, such as queues and associative arrays, into SystemVerilog assertions has sparked ongoing discussion in the hardware verification community. While these constructs enhance assertion capabilities, their support across EDA tools is inconsistent.
This paper addresses the challenges posed by the lack of uniform support for dynamic structures in SVA among tool vendors. It examines the current state of assertion support in major EDA tools, revealing disparities in handling queues and associative arrays. This inconsistency raises questions about the necessity and practicality of these complex structures in assertions.
Despite concerns, the benefits of using queues and associative arrays in specific verification scenarios are significant. The paper explores methods to implement these data structures in assertions, even without direct tool support. It presents techniques for efficient support logic, enabling verification engineers to utilize these structures while maintaining portability and performance.
Additionally, the paper demonstrates these techniques with a simulateable example and explores synthesizable logic as an alternative approach for formal verification environments. This solution aims to bridge the gap between simulation-based and formal verification methodologies.
Activate
Thanks Ben.
Based on the tool error msg above, I tried a code using a virtual interface within concurrent assertion
`include "uvm_pkg.sv"
`include "uvm_macros.svh"
 import uvm_pkg::*;
interface intf;
   logic a , b;
 endinterface
module sva(input bit clk);
   virtual intf  vintf;
     #0;// To ensure get() is done after set
     if( !uvm_config_db#(virtual intf)::get(null,"top_tb","vintf_inst",vintf) )
        `uvm_fatal("sva","Unable to fetch vintf")
   sva1:assert property( @(posedge clk) $rose(vintf.a) |=> vintf.b )
                   else `uvm_error("sva","Assertion fails")
 module top_tb;
   intf intf_inst();
   bit clk;
   initial forever #5 clk = !clk;
     uvm_config_db#(virtual intf)::set(null,"top_tb","vintf_inst",intf_inst);
     // run_test();
   sva   sva_(clk);
     #30; intf_inst.a = 1 ;
Although I ensure that the virtual interface is non-null, prior to 1st clocking event, EDA tools throw an error:
Fatal: (vsim-131) testbench.sv(21): Null instance encountered when dereferencing ‘/top_tb/sva_/vintf.a’
The alternative approach would be to pass each interface via port-list in module ‘sva’
Does the LRM restrict using a virtual interface as a sequence_expression ?
All the variables used in an assertion have to be static at elaboration.
Ben
Here is what I found in LRM
Expressions that appear in concurrent assertions shall satisfy the following requirements:
- Expressions shall not reference non-static class properties or methods
