Can anyone help me with the output of following code and the reason behind it.
class base;
virtual task A();
$display("A called from base class !!");
B();
C();
virtual task B();
$display("B called from base class !!");
task C();
$display("C called from base class !!");
class child extends base;
task B();
$display("B called from extended class !!");
virtual task C();
$display("C called from extended class !!");
task super_A();
super.A();
module test;
base bh;
child ch;
ch = new();
ch.A();
ch.B();
It might help to explain what you expected to see displayed versus what actually gets displayed. Then we can comment on any misunderstandings you might have.
In reply to MarshallX:
Thanks dave for your reply, my question is related?
The output of above code is:
Comment: This is understandable).
Comment: Task B is non-virtual in child class, so task call is based on handle type).
Comment: Task C is virtual in child class, so task call is based on object type, which is type child, but still task getting called is from base class).
Comment: (This is understandable).
“B called from extended class !!
Comment: Task B is non-virtual in child class, so task call is based on handle type).”
This is the expected as according to the LRM section 8.20 Virtual Methods the virtual keyword is optional in the derived classes, In SV once a method is declared as virtual it will be always virtual in all extended/derived classes.
I Think it is the opposite to the previous case in the base class this method is non-virtual so when doing bh.C() it will call the base class method instead, but in all classes extending from child the behaviour will be the same as in B.
module test;
base bh;
child ch;
ch = new();
bh = ch;
ch.A();
ch.B();
ch.C();
bh.C();
#Outputs
# KERNEL: A called from base class !!
# KERNEL: B called from extended class !!
# KERNEL: C called from base class !!
# KERNEL: C called from extended class !!
Regarding
module test;
base bh;
child ch;
ch = new();
bh = ch;
ch.A();
ch.B();
ch.C();
bh.C();
#Outputs
Probably dave_59 will elaborate more.
HTH,
-R
Will be thankful to dave_59 for his views and suggestions.
Another way of thinking about it is to look at the class from the perspective of the class type of the class variable where the handle is stored, not the type of the class object itself. At compile time, it has no way of knowing what object will be stored in the class variable, only that it must be the same type as the class variable or some derivative (I do not like using the term “child” in reference to a derived class). So from the perspective of a base class variable reference bh, A and B are virtual tasks, and C is non-virtual.
The answer is correct.
