I have started learning about verification and UVM recently and wish to test a 16-bit pipelined processor that I made using Verilog. I want to know how to approach the verification of the processor. The processor takes its instruction from a .txt file that has the instruction saved in it. So should I have a driver randomly fill the instruction text file with instructions and run it on the DUT and check coverage or Is there another way to approach a processor verification?
In reply to ShubhamL:
Having instructions in a txt-file is not a good solution, because it does not allow to execute instructions and series of instructions in random order.
Can we not randomize the instructions and write those instructions to a text file and pass the text file to the DUT?
Yes you Can do it, but do you want to do this. It is an additional step you do not Need.
