I am looking at the UVM cookbook and i see the example with pipelined_item_done has 2 sequences one with unpipelined and another with pipelined. I see both the sequences have command and data phase separately. How is the first one non-pipelined and second one pipelined? Can any one help?
class mbus_unpipelined_seq extends uvm_sequence #(mbus_seq_item);
`uvm_object_utils(mbus_unpipelined_seq)
logic[31:0] addr[10]; // To save addresses
logic[31:0] data[10]; // To save data
int error_count;
function new(string name = "mbus_unpipelined_seq");
  super.new(name);
task body;
  mbus_seq_item req = mbus_seq_item::type_id::create("req");
  error_count = 0;
  for(int i=0; i<10; i++) begin
    start_item(req);
    assert(req.randomize() with {MREAD == 0; MOPCODE == SINGLE; MADDR inside {[32'h0010_0000:32'h001F_FFFC]};});
    addr[i] = req.MADDR;
    data[i] = req.MWDATA;
    finish_item(req);
    req.wait_trigger("DATA_DONE"); // I think this should be "CMD_DONE"
  foreach(addr[i]) begin
    start_item(req);
    req.MADDR = addr[i];
    req.MREAD = 1;
    finish_item(req);
    if(req.MRDATA != data[i]) begin
      error_count++;
      `uvm_error("body", $sformatf("@%0h Expected data:%0h Actual data:%0h", addr[i], data[i], req.MRDATA))
endtask: body
endclass: mbus_unpipelined_seq
class mbus_pipelined_seq extends uvm_sequence #(mbus_seq_item);
`uvm_object_utils(mbus_pipelined_seq)
int count; // To ensure that the sequence does not complete too early
function new(string name = "mbus_pipelined_seq");
  super.new(name);
task body;
  use_response_handler(1);
  count = 0;
  for (int i=0; i<10; i++) begin
    start_item(req);
    finish_item(req);
    `uvm_info("", $sformatf("write (i = %0d) of %h at %h", i, req.MWDATA, req.MADDR), UVM_MEDIUM);
  foreach (addr[i]) begin
    start_item(req);
    req.MREAD = 1;
    finish_item(req);
    `uvm_info("", $sformatf("read (i = %0d) of %h at %h", i, req.MRDATA, req.MADDR), UVM_MEDIUM);
  // Do not end the sequence until the last req item is complete
  wait(count == 20);
endtask: body
// This response_handler function is enabled to keep the sequence response FIFO empty
function void response_handler(uvm_sequence_item response);
  count++;
endfunction: response_handler
endclass: mbus_pipelined_seq
