Hi
I was trying to develop an SVA using $past.
Prob stmt: When I see a rising, check that busy was asserted sometime before(any number of clock cycles earlier).
assert property(@(negedge clk)($rose(a)|->$past(busy,[1:$]));
However I get syntax error, doesn’t past support [1:] ?
Or is there a better way I can achieve the functionality check ?
Any help is much appreciated.
Regards
ben2
2
In reply to bharath_1800:
Questions for you:
- How often is busy set to 1’b1?
- When is busy reset?
An easy solution is to set a latch (ambusy) when busy is set. Reset the latch (ambusy) when the assertion passes or fails. For example:
timeunit 1ns; timeprecision 100ps;
bit clk,busy, a;
bit ambusy; // ff
always @(posedge clk) if(busy) ambusy <= 1'b1;
ap_a_was_bysy: assert property(@(negedge clk)$rose(a)|-> ambusy)
ambusy=1'b0; else ambusy=1'b0;
initial forever #10 clk=!clk;
repeat(2000) begin
@(posedge clk);
if (!randomize(a, busy) with
{ a dist {1'b1:=1, 1'b0:=3};
busy dist {1'b1:=1, 1'b0:=6};
$stop;
See Paper: VF Horizons:PAPER: SVA Alternative for Complex Assertions - SystemVerilog - Verification Academy
