bit condition;
bit arr1 [4][8];
bit arr2 [4][8];
int i,j;
function automatic void some_func(ref bit arr[4][8]);
arr*[j] = 1;
some_func(condition ? arr1 : arr2);
The point of the “some_func” function is to be flexible to receive either arr1 or arr2 depending on “condition”. The function will then alter the contents of whichever array it is given. However, I get a compilation error:
[i] Illegal value (condition ? arr1 : arr2) for ref formal (arr). Value must be assignable.*
Expression evaluation is unidirectional and not available as the target of an assignment. What if you had
int A = 1;
function automatic void some_func(ref int arg);
arg = arg + 2;
some_func(A + 1);
$display(A);
You would not expect A to have the value 3, would you?.
The only operators allowed in the target of an assignment are concatenation and streaming operators.
Depends on what your definition of “elegant” is. You could use a class
class A;
bit arr [4][8];
bit condition;
A arr1 = new;
A arr2 = new;
int i,j;
function automatic void some_func(A h);
h.arr[i][j] = 1;
This looks very close to your original example code. But I’m guessing it’s very simplified from your actual code.
