Passing parameters to a bind entity
Hi all,
I am trying to bind parameters of my rtl to my assertion module.
Parameter values change at the simulation time based on the different configurations and I want them to be bound to the assertions.
Any inputs on whats the best way to do this?
bind rtl_module asst_module asst_module_inst #(
.parameter1 (parameter1),
.parameter2 (parameter2)
I tried this way but seems to be not working.
Leela
In reply to leela:
It would help greatly if you can explain further what you mean by “not working”. Are you getting a compiler error? Or not getting the results you expect?
You cannot change
parameter
values during a simulation; they are pre-simulation constants. You can pass values that change as regular ports to a bound module.
sorry if I was not really clear… I was getting a compiler error… but I think I fixed it and its working now.
I tried binding the parameters as follows:
bind rtl_module asst_module #(
asst_module_inst (.clk(clk),
.rst(rst));
what i mean by changing the parameters during simulation time is that there are different configurations with different parameter values and it changes based on what configuration i choose.
Thanks Dave!
