Passing data through constructor
Is the fixed prototype requirement of the factory essentially is meant to discourage passing arguments through the constructor ?
Sometimes it is very handy to pass an integer through constructor. I am not able to achieve the same through parameters. I think they are fixed at compile time.
program test;
  import uvm_pkg::*;
  class compA #(int unsigned id = 10) extends uvm_component;
    `uvm_component_param_utils(compA#)
    //`uvm_component_param_utils(compA#(id))
    function new(string name = "compA", uvm_component parent = null);
      super.new(name, parent);
    function void display();
      $display("ID = %0d", id);
  class env extends uvm_test;
  `uvm_component_utils(env)
    compA compa_h;
    function new(string name = "env", uvm_component parent = null);
    function void build();
      compa_h = compA#(20)::type_id::create("compa_h", this);
      compa_h.display();
    run_test();
endprogram
What is the recommended way to pass information during construction of an object ?
That’s what the config class is for. See Configuration | Verification Academy
Thats useful.
Although if one needs to set ID’s for sequences while they get created. It may be easier to actually pass it through the constructor. Instead now, i have to call a function that sets the ID after I create the sequence.
Ex:
lane_seq lane_seq_h[NUM_LANES];
foreach(lane_seq_h[i])
if(lane_seq_h[i] == ACTIVE)
lane_seq_h[i] = lane_seq::type_id::create(“lane_seq_h”);
lane_seq_h[i].set_lane_id(i);
In reply to sohels:
I think you will find that in the long run that using the factory with the configuration mechanism is easier to write test without having to modify a chain of constructor arguments when you need to add a new ID or whatever to the sequence.
Hello! I have a similar problem, and I am still not quite getting it. Check out my driver class below. I want to use it to connect to a DUT with the same interface multiple times – specifically a mutli-port memory port memory controller with several clients. Therefore, I will have multiple independent, but identical, virtual interfaces instantiated at the top level, shown below. It is the following line in the driver class that bothers me: assert (get_config_object(“vif_c0”, obj, 0));
I need to be able to get the config object using the correct name “vif_c0”, “vif_c1”, … “vif_cN”. How should I do this?
Thanks in advance!
Aaron
** From top level, instantiate virtual interfaced between driver and DUT
generate
// Construct the virtual interfaces…
for (genvar i = 0; i < `NUM_MEM_CLIENTS; i++)
initial vifc [i] = new (difc[i]);
endgenerate
string my_vif_name;
for (integer i = 0; i < `NUM_MEM_CLIENTS; i++) begin
  my_vif_name = $sformatf("vif_c%0d", i);
  `ovm_info("top.sv; virtual interface names", my_vif_name, OVM_MEDIUM)
  set_config_object("*", my_vif_name, vifc[i], 0);
end // for loop
 vif_server = new(dif_server);
 set_config_object("*", "vif_s", vif_server, 0);
 `ovm_info("top.sv", "... run_server_test() ...", OVM_MEDIUM)
 run_test();
** Driver Class
class tb_driver_mem_client extends ovm_driver #(trans_item_mem_client);
`ovm_component_utils(tb_driver_mem_client)
virtual dut_if_client vif_client;
function new (string name, ovm_component parent);
function void build ();
super.build();
assign_vi;
function void assign_vi;
ovm_object obj;
dut_if_client_wrapper w;
assert ($cast(w, obj));
vif_client = w.vif;
extern task run();
extern task initialize (trans_item_mem_client tx);
extern task drive_item (trans_item_mem_client tx);
You can use a static int and increment it in constructor. then use the same to get the appropriate interface.
static int id_static = -1;
int id;
 id_static++;
 id = id_static;
assert (get_config_object($psprintf("vif_c%0d", id), obj, 0));
Hope this helps
worked perfectly, thank you!
