Hello,
I have PARAMETERIZED AGENT CLASS, whose multiple instances I will take in the environment, I need to pass different PARAMETERS to different agents.
I have an array of PARAMETERS, which I need to pass in the environment to multiple agents.
e.g PARAMETER ADDR_WIDTH [2:0] = {32,32,64};
PARAMETER DATA_WIDTH [2:0] = {32,32,64};
In env, delaring agent handle
abc_agent_c (ADDR_WIDTH,DATA_WIDTH) agent_h; (typically in env.svh)
How I can pass array of parameters to a single handle declaration. As I see cannot use genvar/for loop for same.
Do I have to define multiple agent handles & pass the array e.g abc_agent_c (ADDR_WIDTH[0],DATA_WIDTH[0]) agent_h_1;
abc_agent_c (ADDR_WIDTH[1],DATA_WIDTH[1]) agent_h_2;
Or is there some other workaround, please suggest.
In reply to deepa.djdoll:
You’re not going to like the answer, but unfortunately you can’t do this in a compact manner. You’re going to have to write each instance out:
abc_agent_c (ADDR_WIDTH[0],DATA_WIDTH[0]) agent_h_0;
abc_agent_c (ADDR_WIDTH[1],DATA_WIDTH[1]) agent_h_1;
abc_agent_c (ADDR_WIDTH[2],DATA_WIDTH[2]) agent_h_2;
In reply to Tudor Timi:
Thanks for your reply Tudor.
I moving ahead with this approach currently.
But, when I have delared e.g 5 Agent_handles.
- Now I have a PARAMETERIZED AGENT CONFIG CLASS which I need to PASS to base sequence.
- How I can provide this AGENT_CFG for each AGENT independently(e.g 1 sequence per AGENT_MASTER)?
- I am able to provide the same to my “master_sequences” which is extended from “base_sequence” but unable to do the same for “base sequence” itself.
I don’t get what you mean by “provide the agent_cfg for each agent independently”.
Where does this base sequence of yours run? On which sequencer? Some agent sequencer or a virtual sequence that is connected to all four agents? Some code of what your doing might also be helpful.
There is a parameterized packet data class that contains parameterized agent_cfg. This agent cfg is used to randomize few fields
inside packet class. So we want to pass this agent_cfg to each parameterized sequence that are given to each individual
parameterized master agent.For this we have single parameterized virtual sequencer which contains different parameterized physical master sequencers. Master sequencer contains agent_cfg handle. Master sequencer agent cfg handle has already been assigned,
master agent’s agent_cfg in our agent. So our sequencer gets the agent_cfg. We also have parameterized base sequence which
contains agent_cfg handle. And we have master sequence that is extended from base sequence.
So our issue is how to pass agent cfg to base sequence and master sequence??
e.g-
Virtual Sequencer
class multi_master_slave_virtual_sequencer#(int DATA_BUS_WIDTH=32, int ADDR_BUS_WIDTH=32 , int NUM_OF_MASTER = 2, int NUM_OF_SLAVE = 2) extends uvm_sequencer #();
master_sequencer #(write_data_cls#(DATA_BUS_WIDTH,ADDR_BUS_WIDTH),DATA_BUS_WIDTH[0],ADDR_BUS_WIDTH[0]) write_addr_ch_sqr_0 ;
master_sequencer #(write_data_cls#(DATA_BUS_WIDTH,ADDR_BUS_WIDTH),DATA_BUS_WIDTH[1],ADDR_BUS_WIDTH[1]) write_data_ch_sqr_1 ;
class base_sequence #(int DATA_BUS_WIDTH=32,int ADDR_BUS_WIDTH=32) extends uvm_sequence#(abc_data);
agent_config_c #(DATA_BUS_WIDTH,ADDR_BUS_WIDTH) agent_cfg;
rand bit [ADDR_BUS_WIDTH - 1:0] seq_addr;
constraint burst_c {
if(agent_cfg.DEV_TYPE == ABC)
seq_addr == 32’h0000_0000;
else
seq_addr == 32’h1000_0000;
class random_master_seq#(int DATA_BUS_WIDTH=32,int ADDR_BUS_WIDTH=32) extends base_sequence #(DATA_BUS_WIDTH,ADDR_BUS_WIDTH);
void’(uvm_config_db #(agent_config_c#(_DATA_BUS_WIDTH,
_ADDR_BUS_WIDTH))::get (null, get_full_name(),“seq_agent_config”,req.agent_cfg));
Have you tried getting the config handle from the sequencer on which the sequence is running?
`uvm_declare_p_sequencer(master_sequencer #(...))
This macro will create a variable called p_sequencer of the type you pass to it. UVM will take care that it contains the sequencer on which the sequence was started. You can then reference the config with p_sequencer.cfg.
deepa,
Using a macro ‘uvm_declare_p_sequencer’ is a good idea.
To get a handle of sequencer::cfg, in the sequence pre_randomization can be used.
function void pre_randomize();
agent_cfg get_cfg;
// alternate 1 : should be avoided
get_cfg = p_sequencer.seqr_cfg;
//alternate 2 : should be used
p_sequencer.get_cfg(get_cfg); // get_cfg is a method defined in sequencer which 'references' is it's seqr_cfg !
// This method should be used because if there is any change in agent::seqr_cfg, those changes are available in sequence
// casting and rest required
endfunction : pre_randomize
