i have an issue when passing a structure of logic signals from a submodule to the topmodule.
i stripped the code down to minumum to only show the part resulting in the issue.
there is a .h file called ptc_structure.h, where the structure is defined:
typedef struct {
logic pWRT_PLLRESET;
logic pWRT_PLLSWITCH;
logic [2:0] pWRT_SELECT;
} st_PTC_WRT;
both, the topmodule (PTC.sv) and the submodule (P_AVSIF.sv) include the .h file above.
in the module header of the submodule (P_AVSIF.sv), i have
module P_AVSIF (
output st_PTC_WRT s_pWRT
and in the topmodule (PTC.sv), i have
st_PTC_WRT s_pWRT;
P_AVSIF AVSIF (
.s_pWRT (s_pWRT)
when running questasim, i get the error message below:
** Error: (vsim-3906) Connection type ‘struct PTC_sv_unit::st_PTC_WRT’ is incompatible with ‘struct P_AVSIF_sv_unit::st_PTC_WRT’ for port (s_pWRT): Struct/union types must match.
to me, this message looks like the definition of the structure, used to define s_pWRT is different within the two files. but fact is, that both files use the definition from ptc_structure.h, i.e. it is the same for both.
so what am i doing wrong?
