Hi, I have a serval questions about using parametrized interface.
consider the next interface:
interface my_interface #(parameter DATA_WIDTH, PORT_NUM_WIDTH);
logic clk ;
logic rst ;
logic mready;
logic tvalid;
logic [DATA_WIDTH -1:0] tdata ;
logic [PORT_NUM_WIDTH -1:0] tdest ;
endinterface: my_interface
now consider I want to instantiate this interface twice in my top file with different widths in each interface, for example:
my_interface #(12,2) interface_1;
my_interface #(10,4) interface_2;
(if it’s not the right way to instantiate please let me know).
my first question is as follow:
if I want to add this interface to the config_db, should I specify the parameters like:
uvm_config_db#(virtual interface my_interface#(12,2))::set(uvm_root::get(), * ,"intf1" , my_inteface_1)
uvm_config_db#(virtual interface my_interface#(10,4))::set(uvm_root::get(), * ,"intf2" , my_inteface_2)
Or should I write it without the paramters like:
uvm_config_db#(virtual interface my_interface)::set(uvm_root::get(), * ,"intf1" , my_inteface_1)
uvm_config_db#(virtual interface my_interface)::set(uvm_root::get(), * ,"intf2" , my_inteface_2)
my next question is:
if I want to have pointers in some agent to these two interfaces how should I declare them?
virtual my_interface #(12,2) agent_if_1;
virtual my_interface #(10,4) agent_if_2;
Or
virtual my_interface agent_if_1;
virtual my_interface agent_if_2;
I guess that the get from the config_db is done in the same way as the set to the config_db in manners of specify the interface with/without its parameters(if not tell me
Moshiko
