IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
class base_sequencer #(type REQ = base_seq_item,
type BYPASS = base_seq_item,
type SUBSCRIBER = base_sequencer)
extends uvm_sequencer #(REQ);
Is there any problem with the way “type SUBSCRIBER = base_sequencer” is declared in the above code? Is this a legal way of declaring or does this result in a recursive call?
I want to create 2 objects of the above class type, one of which I want to parameterize SUBSCRIBER with another class type while for the other object I don’t want to. Is this possible with the above code?
What is the difference of the above code with this -
type SUBSCRIBER)
Thanks for the response, Dave. How about the 2nd syntax, does that work?
I am trying to make the following implementation.
`uvm_analysis_imp_decl(_bypass);
type SUBSCRIBER)
`uvm_component_param_utils(base_sequencer#(REQ, LOOPBACK_REQ, SUBSCRIBER));
uvm_analysis_imp_bypass #(BYPASS, SUBSCRIBER) bypass_port;
//! Subscriber function for bypass transaction
function void write_bypass (BYPASS trans);
//Logic to receive and store the trans
endfunction : write_bypass
I have sequences that are reactive, i.e they need to get driven based on transactions seen from other agents. I am using the other agent’s sequencer as the subscriber. And the other agent’s transaction type is ‘BYPASS’.
So let’s say the names of the agents are base_agent and other_agent. This is what I have in my env -
function void connect_phase (uvm_phase phase);
super.connect_phase(phase);
other_agent.monitor.mon_analysis_port.connect(base_agent.sequencer.bypass_port);
endfunction : connect_phase
Now I also have sequences which don’t need these connections. For these I don’t want to change the SUBSCRIBER type and leave it as it is.
