Why it is not mandatory to override the time consuming phases(task based phases) by calling super method, for instance in run_phase, super.run_phase(uvm_phase); , but as it is mandatory to override the function based phases by calling super method.
In reply to Munsif M.Ahamd:
It is never mandatory to call super. on any phase. As far as I know non of the uvm_component phases have anything in them except the build_phase. That is only needed if you use the field automation macros, which we do not recommend.
