Overriding inner package define from the Testbench
Hi ,
Need to override some package define from the top (outside the package).
package bu ;
ifndef ABC define ABC 100
`endif
endpackage
module top ;
`define bu::ABC 111
import *::bu ;
The above code is valid but the definition ABC still not overridden .
Is there some method to do this .
Thanks in advance.
Vlad
In reply to vladr:
Text define macros get processed before parsing any SystemVerilog syntax - a macro definition is not part of any scope including a package. Use parameters instead.
package bu ;
parameter ABC=100;
endpackage
module topA ;
  import bu::*;
  parameter ABC=111;
  initial $display(ABC); //displays 111
module topB ;
  import bu::*;
  initial $display(ABC); //displays 100
