Override sc in uvm_analysis_imp
I have a base monitor class wtih an uvm_analysis_imp …
class base_mon#(type REQ=base_pkt, type RSP=REQ) extends uvm_component;
`uvm_component_utils(base_mon)
uvm_analysis_imp#(base_pkt, base_mon) drvr_mon_import;
function new(string name, uvm_compnent parent);
drvr_mon_import = new(“drvr_mon_import”, new);
I want to use the above port in an extended monitor class …
class mod1_mon extends base_mon;
Since the analysis_imp has to point to the subscriber, I’m confused as how to override the subscriber in the extended class.
Kalai
In reply to kalai12345:
First, imp stands for implementation.
Second, drvr_mon_import = new(“drvr_mon_import”, new); is wrong. The second Argument has to be of type uvm_component and is not a constructor call.
Third, imp means you have to implement the write function.
my bad.
It should be
drvr_mon_import = new(“drvr_mon_import”, this).
Anyhow, with some online help, I could reuse the analysis_imp declared from the base class in the extended class by having a typedef of the base class within the base class and then passing that handle to the uvm_analysis_imp’s 2nd arg.
Kalai
