Override parameterized base driver with a driver extended from it
hello:
I want to override parameterized base driver with a driver extended from it by type. but i get some strange error in questa sim.
I have a base driver defined like this:
class eth_rx_driver#(type CHILD_RW=eth_rw) extends uvm_driver #(CHILD_RW);
`uvm_component_param_utils_begin(eth_rx_driver#(CHILD_RW))
endclass: eth_rx_driver
and I extend another driver from it .
class ipv4_rx_driver extends eth_rx_driver #(ipv4_rw) ;
  `uvm_component_utils(ipv4_rx_driver)
endclass: ipv4_rx_driver
in the agent i created the eth_rx_driver like this.
class eth_rx_agent extends uvm_agent;
eth_rx_driver #(eth_rw) drv;
drv = eth_rx_driver#(eth_rw)::type_id::create(“drv”, this);
endclass: eth_rx_agent
I included all these drivers and agent in one SV package.
and in the test I try to override the driver like this.
class ipv4_test extends uvm_test;
set_type_override_by_type(eth_rx_driver#()::get_type(), ipv4_rx_driver::get_type());
super.build_phase(phase);
factory.print();
endfunction : build_phase
when I try to compile the code in questasim, there is no error. but in build phase, it shows
UVM_FATAL @ 0: reporter [FCTTYP] Factory did not return a component of type ‘eth_rx_driver’. A component of type ‘ipv4_rx_driver’ was returned instead. Name=drv Parent=eth_rx_agent contxt=uvm_test_top.eth_example_tb0.eth0.masters[0]
I want to use the ipv4 driver to replace the eth driver, but how this error comes? is there anything wrong with my factory operation ?
The problem is that you’ve defined ipv4_rx_driver as extended from eth_rx_driver#(ipv4_rw), but you’ve tried to override it from eth_rx_driver#(eth_rw). Remember that eth_rx_driver#() uses the default parameterization, which is NOT what you extended ipv4_rx_driver from.
Try doing
eth_rx_driver#(ipv4_rw)::type_id::set_type_override(ipv4_driver::get_type());
You’ll also note that I used the type-specific static call to set_type_override() instead of set_type_override_by_type(). Personal preference to a degree, but using the static method as I’ve shown is a bit more efficient.
-Tom
thank you for your solution, you do solved my problem.
but I get a little confused about the situation. I instantiated the eth_rx_driver #(eth_rw) in the agent. but in the test, I override eth_rx_driver#(ipv4_rw) by ipv4_driver, the type eth_rx_driver #(eth_rw) which i really want to override is not really overrided.
I try to change the class inheritance to
class ipv4_rx_driver extends eth_rx_driver #(eth_rw) ;
and try to use in the test
eth_rx_driver#(eth_rw)::type_id::set_type_override(ipv4_driver::get_type());
it should solve the problem of incorrect overriding, but in the send_pkt function of driver, the input parameter is the packet type.
virtual protected task send_pkt(CHILD_RW tr);
so the parameter of send_pkt in eth_driver and ipv4_driver is different, the compiler report error on this.
how could I solve this problem. is there any guideline for such parameterized overriding ?
I want to reuse some code in the eth_driver, and the ipv4_driver can replace it in some situation.
thanks.
In reply to jie:
I defined eth_rw and ipv4_rw for both driver and ipv4_rw is extended from ipv4_rw. I also used
set_type_override_by_type(eth_rw::get_type(), ipv4_rw::get_type());
in the test
I tried
virtual protected task send_pkt(eth_rw tr);
ipv4_rw ipv4_tr;
if (!$cast(ipv4_tr,tr)) begin
it seems to work, is it compulsory to cast the type for different input type?
