Hello,
I am new with UVM environment so please can anyone tell me why the override instance functionality is their in UVM. what it is the need of it ?
Can anyone explain me with a simple example that how one instance is exactly overridden ?
In reply to Huzefa Halolwala:
I have design one simple testbench in which there are two driver classes
- driver (drv)
- driver2 (drv2)
and I want to override the instance with driver2 (drv2), But it is showing me the result as drv not the replaced one drv2. This is what i have written in my testcase
driver::type_id::set_inst_override(driver2::get_type(),"top.t_env.ag2.drv2");
The override command needs 3 arguments:
function void set_inst_override( string relative_inst_path,
string original_type_name,
string override_type_name)
But in the output it is showing me that the factory has granted the request for overriding.
Instance Overrides:
Requested Type Override Path Override Type
driver top.t_env.ag2.drv2 driver2
Here is my code:
------------------ Agent ------------------
class agent extends uvm_agent;
`uvm_component_utils(agent)
protected uvm_active_passive_enum is_active = UVM_ACTIVE;
monitor mon;
driver drv;
// driver_2 drv2;
//monitor_2 mon2;
super.new(name, parent);
function void build();
uvm_report_info(get_full_name(),"Build", UVM_LOW);
mon = monitor::type_id::create("mon",this);
drv = driver::type_id::create("drv",this);
// ag2 = agent::type_id::create("ag2",this);
// mon2 = monitor_2::type_id::create("mon2",this);
// drv2 = driver_2::type_id::create("drv2",this);
--------------------------- Agent 2 derived from Agent-------------
class agent2 extends agent;
`uvm_component_utils(agent2)
monitor2 mon2;
driver2 drv2;
mon2 = monitor2::type_id::create("mon2",this);
drv2= driver2::type_id::create("drv2",this);
---------------- env --------------------
class env extends uvm_env;
`uvm_component_utils(env)
agent ag1;
agent2 ag2;
ag1 = agent::type_id::create("ag1",this);
ag2 = agent2::type_id::create("ag2",this);
---------------- testcase------------------
class test2 extends uvm_test;
`uvm_component_utils(test2)
env t_env;
function new (string name="test2", uvm_component parent=null);
super.new (name, parent);
factory.print();
t_env = new("t_env",this);
endfunction : new
Output :
Instance Overrides:
Name Type Size Value
uvm_test_top test2 - @455
t_env env - @463
ag1 agent - @471
drv driver - @495
rsp_port uvm_analysis_port - @512
seq_item_port uvm_seq_item_pull_port - @503
mon monitor - @487
ag2 agent2 - @479
drv2 driver2 - @533
rsp_port uvm_analysis_port - @550
seq_item_port uvm_seq_item_pull_port - @541
mon2 monitor2 - @525
Your second argument is wrong. You have to indicate the instance which has to be overwritten and this is drv and not drv2:
driver::type_id::set_inst_override(driver2::get_type(),“top.t_env.ag2.drv”);
For an example see
https://verificationacademy.com/cookbook/cookbook-code-examples#UVM_Examples:#UVM_Examples:#UVM_Examples:
Overriding
