I can’t use set_type_override_by_type() if the parent class has a “name-duplicate” in another package.
The packages and the classes:
package a_pkg;
import uvm_pkg::*;
class parent_obj extends uvm_object;
`uvm_object_utils(parent_obj)
function new(string name = "parent_obj");
super.new(name);
endfunction : new
virtual function void do_thing();
`uvm_info(get_name(), $sformatf("I'm parent in A"), UVM_LOW)
endfunction : do_thing
endclass : parent_obj
endpackage : a_pkg
package b_pkg;
import uvm_pkg::*;
super.new(name);
endfunction : new
`uvm_info(get_name(), $sformatf("I'm parent in B"), UVM_LOW)
class child_obj_b extends parent_obj;
`uvm_object_utils(child_obj_b)
function new(string name = "child_obj");
super.new(name);
endfunction : new
`uvm_info(get_name(), $sformatf("I'm child in B"), UVM_LOW)
endclass : child_obj_b
endpackage : b_pkg
The test:
class base_test extends uvm_test;
`uvm_component_utils(base_test)
super.new(name, parent);
uvm_factory factory = uvm_factory::get();
super.build_phase(phase);
factory.set_type_override_by_type(b_pkg::parent_obj::get_type(), b_pkg::child_obj_b::get_type());
endfunction : build_phase
b_pkg::parent_obj b_pkg_parent_obj = b_pkg::parent_obj::type_id::create("b_pkg_parent_obj");
a_pkg::parent_obj a_pkg_parent_obj = a_pkg::parent_obj::type_id::create("a_pkg_parent_obj");
phase.raise_objection(this);
b_pkg_parent_obj.do_thing();
a_pkg_parent_obj.do_thing();
super.run_phase(phase);
phase.drop_objection(this);
endclass : base_test
The result:
UVM_WARNING @ 0: reporter [TPRGED] Type name 'parent_obj' already registered with factory. No string-based lookup support for multiple types with the same type name.
UVM_INFO @ 0: reporter [RNTST] Running test base_test...
UVM_FATAL @ 0.0 ns: reporter [FCTTYP] Factory did not return an object of type 'parent_obj'. A component of type 'child_obj_b' was returned instead. Name=a_pkg_parent_obj Parent=null contxt=
UVM_INFO /org/seg/tools/eda/cadence/xcelium/22.03.v006/tools/methodology/UVM/CDNS-1.2/sv/src/base/uvm_report_catcher.svh(705) @ 0.0 ns: reporter [UVM/REPORT/CATCHER]
What should I do instead?
Also, why isn’t it working?
