I would like to know how to compute the simulation overhead of sampling a covergroup every clock cycle instead of sampling only at the required instant .
Omkar
Omkar
*In reply to o-hassan:*There are too many unknowns to answer this predictably.
You may just have to try some experiments.
I just want to find out the simulation time/memory overhead when i sample at every clock edge instead of calling covergroup.sample at the right instant. You can assume the complexity to compute that instant and the complexity of bin expression is negligible.
c. That’s something I am not doing. Could you please tell me how to do that ?
d. Probably around 1000 clock cycle.
c. This forum is not for tool specific support. Contact your vendor for tool specific help for performance guidelines.
d. I meant what percentage into the simulation. Turning off covergroups once they hit 100% coverage has more impact if that happens early in the simulation
A covergroup is just a set of counters that get allocated when you call the covergroup’s constructor. The sampling rate has no effect on the total memory consumed. But more counters actively being used means more active memory that needs to be cached.
