extern virtual function void read_line(<*old arg>, ref bit value=1’b0 );
Is it possible to add optional ref/output arguments for a function? I am adding a new argument now, but don’t want to change all the old files which need this same function except for 1 file where I need this new argument but uses the same function in several places.
Illegal connection to the ref port ‘value’ of function/task
‘model_pkg_c_2149966356_29::read_line’,formal argument
should have same type as actual argument.
You can do this, but the default argument needs to compatible as if it was actually used as an argument. You cannot pass a constant literal in the place of a ref argument. You will need to write
bit dummy;
extern virtual function void read_line(<**old arg*>, inout bit value=dummy );
Now dummy is the variable used by read_line.
BTW, there are very few good reasons to ever use “ref” as a function argument direction. Much better to use input, output or inout as these have fewer restrictions than ref.
