Hi Team ,
module test;
reg signed [8:0] sin_hall2;
sin_hall2 = -9'd4 ;
$display( "Comparison unsigned : %b ", sin_hall2 > 9'd1 );
$display( "Comparison cast : %b ", sin_hall2 > $signed(9'd1) );
In the above example i am trying to understand but missing something . Please help
Here is my understanding :
- sin_hall2>9’d1:
In this sin_hall2 = -(9’sb11111_1100) > 9’b00000_0001;
After 2’s complement
9’b00000_0100 >9’b00000_0001 /// result is true -->1
- **sin_hall2 > $signed(9’d1)
-(9’sb11111_1100) >9’sb00000_0001;
9’b00000_0100 >9’b00000_0001 /// result is true -->1 —>but simulator gives 0 as output
Please provide some inputs on how these operations signed and unsigned comparison works in this context
Please help me to get the difference of $signed(9’d1) and 9’d1 and 9’sd1 with respect to operators .
Thanks in Advance
Regards,
Mechanic
You are doing an extra 2-complement. The signedness of an operand does not change the bits, just its interpretation for certain operations like relations and extension.
9’d4 is a 9-bit unsigned value 9’b00000_0100. When you apply unary minus (2’s complement) it becomes the 9-bit unsigned value 9’b11111_1100, which is 508 decimal. That get stored in th 9-bit signed variable sin_hall2. The bits do not change, but it is now interpreted as the signed value -4. It would not matter if you had used 9'sd4 instead.
When comparing two values, both must be signed to do a signed comparison. Since 9'd1 is unsigned, the first comparison is 508 > 1, which is true (1’b1).
In the second comparison, you could write $signed(9'd1), signed'(9'd1), or 9'sd1. Any of those would make both operands signed, so the operation is now a signed comparison. -4 is not greater than 1, the result is 1’b0.
Hi Dave
Thank you
Could you please provide some examples for the below statement
I have tried the below example with extended form please correct me if i miss something
module test;
logic signed [3:0] a;
logic signed [7:0] b,c;
a=7;
$display("value of a is %b ",a);
b= a<<1;
$display("b=%b", b);
c= signed'(a<<1);
$display("c=%b",c);
//Operation expanded
//b= a<<1;
// 0000_0111<<1 ///first sign extended then shifting
//0000_1110
//c= signed’(a<<1);
//c= signed’(1110) // first shifting then sign extended
//c= 1111_1110
That is correct. Another way to think of this is converting from signed to unsigned, or from unsigned to signed does not modify any bits of a value. It will change how certain operations behave, producing different value results. Your original example shows the difference in relational operatos, and this next example show the difference in extension.
