I am doing some verification task and happen to meet the scenario of one monitor and two scorebaord.
Can you please help me where i can find the material to read in Verification Academy or where is the download link
where i can find the examples to download.
You can connect any number of scoreboards or coverage collectors to monitor. If you want to compare something in a scoreboard you need at least 2 inputs to the scorboard. You should explain where the second input comes from.
When the analysis port writes to each scoreboard, the two scoreboards will each wind up with a handle to the same data object. So, if you modify the contents in one scoreboard, it will be reflected in the other. This may not be what you want. Please see the UVM Guidelines page, Rule 10.1, “MCOW”
