Observe UVM_ERROR during Backdoor Access
Hi All ,
I am referring to source code available related to Backdoor Access .
One such useful link is cluelogic_backdoor_access
However when I try to execute the code with some local changes I observe run-time error ::
UVM_ERROR: set: unable to write to hdl path (top.dut.partner.color_and_flavor)
You may not have sufficient PLI/ACC capabilites enabled for that path
UVM_ERROR: set: unable to write to hdl path (top.dut.partner.extra.sugar_free)
UVM_ERROR: set: unable to write to hdl path (top.dut.partner.extra.sour)
Link to my code :: eda_backdoor_access .
I observe the above error when running test jelly_bean_reg_test via run-time switch :: +UVM_TESTNAME=jelly_bean_reg_test
The hierarchy mentioned in the error messages top.dut.partner.color_and_flavor , top.dut.partner.extra.sugar_free and top.dut.partner.extra.sour
does exist in the actual RTL hierarchy from top
Seek guidance for the same .
Thanks .
In reply to hisingh:
This is a tool related issue. You will need to refer to the tool documentation on how to enable PLI/ACC access, or try a different simulator.
In reply to cgales:
I added some uvm_info messages ( Link :: edaplayground ) within the body() task and re-ran the test .
On running it using other tools although I don’t observe any error message ,
I don’t observe the info messages either .
Hence I feel like it could be a RAL TB issue instead of tool related .
You don’t get error messages with the other tools because they allow PLI/ACC access.
You don’t see any uvm_info messages because the environment isn’t UVM compliant:
  • Tests and sequences have #delays. Per the UVM, the entire environment should have no #delays.
  • The test doesn’t raise/lower an objection in the run_phase(), resulting in the test exiting immediately at time 0.
There is nothing wrong with the RAL implementation.
In reply to cgales:
Thanks .
I was trying to debug from RAL perspective but as you pointed the issue is related to raising and dropping objections .
[ EDIT : VCS requires Compile switch -debug_access+all to to enable PLI/ACC access ]
