How is casting an object handle different from assigning the handle ? As I understand, casting is an assignment with an additional compatibility check. Is that correct ?
Example:-
line1: parent_handle = child_handle;
line2: if (!($cast(child_handle,parent_handle))) $error(“cast error”);
line3: child_handle = parent_handle;
In the above example, either having just line 2 or line 3 alone should result in the same behavior. Is that correct ?
Regards
Amith
