Kindly help me to understand how this is possible to get and put the number of keys which is not initialized in new as per given below:
module tb();
semaphore sem = new(3);
task process_A();
sem.get(3);
$display("process_A is started");
#5ns;
$display("process_A is completed");
sem.put(5);
task process_B();
sem.get(5); // Accessing more keys than initialized
$display("process_B is started");
#5ns;
$display("process_B is completed");
sem.put(5);
task process_C();
sem.get(6); // Accessing more keys than available in the bucket
$display("process_C is started");
#5ns;
$display("process_C is completed");
sem.put(5);
process_A();
process_B();
process_C();
join_none
It gives the below output:
Hi Hardik,
Thanks, I understood your points. One more doubt is there:
We are creating 3 keys in new. Then what is the point in putting back 5 keys, we have not created these 2 extra keys. Considering the process_A() only, how we can putting(or put()) which we are not getting . Is it good practice to code in this way.
This is a weakness in the functionality of the semaphore class. Important is you should be aware of this and double-check how many keys you are putting back.
The semaphore class is a primitive construct serving various purposes, such as process synchronization and resource allocation. The user of the semaphore is responsible for managing the allocation of keys. Typically, a semaphore is encapsulated within another class that manages the keys. In most applications, the key count is always set to 1.
