Null pointer dereference bucause of print in connect_phase
class yapp_tx_agent extends uvm_agent;
  //  This field determines whether an agent is active or passive.
  protected uvm_active_passive_enum is_active = UVM_PASSIVE;
  yapp_tx_monitor   monitor;
  yapp_tx_sequencer sequencer;
  yapp_tx_driver    driver;
  // component macro
  `uvm_component_utils_begin(yapp_tx_agent)
    `uvm_field_enum(uvm_active_passive_enum, is_active, UVM_ALL_ON)
  `uvm_component_utils_end
  // Constructor - required syntax for UVM automation and utilities
    super.new(name, parent);
  endfunction : new
  // UVM build_phase() method
    super.build_phase(phase);
    monitor = yapp_tx_monitor::type_id::create("monitor", this);
    if(is_active == UVM_ACTIVE) begin
      sequencer = yapp_tx_sequencer::type_id::create("sequencer", this);
      driver = yapp_tx_driver::type_id::create("driver", this);
  endfunction : build_phase
  // UVM connect_phase() method
      // Connect the driver and the sequencer
      driver.seq_item_port.connect(sequencer.seq_item_export);
      //driver.print();
  endfunction : connect_phase
  function void start_of_simulation_phase(uvm_phase phase);
    `uvm_info(get_type_name(), {"start of simulation for ", get_full_name()}, UVM_HIGH);
  endfunction : start_of_simulation_phase
endclass : yapp_tx_agent
if I uncomment the driver.print() line from connect_phase…I get following error…
ncsim: *E,TRNULLID: NULL pointer dereference.
File: /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_object.svh, line = 901, pos = 30
Scope: worklib.uvm_pkg::uvm_object::sprint
Time: 0 FS + 13
Verilog Stack Trace:
0: function worklib.uvm_pkg::uvm_object::sprint at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_object.svh:901
1: function worklib.uvm_pkg::uvm_object::print at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_object.svh:880
2: function worklib.yapp_pkg::yapp_tx_agent@4931_3.connect_phase at …/sv/yapp_tx_agent.sv:52
3: function worklib.uvm_pkg::uvm_connect_phase@1966_3.exec_func at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_common_phases.svh:101
4: function worklib.uvm_pkg::uvm_bottomup_phase@1966_3.execute at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_bottomup_phase.svh:104
5: function worklib.uvm_pkg::uvm_bottomup_phase@1966_3.traverse at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_bottomup_phase.svh:81
6: function worklib.uvm_pkg::uvm_bottomup_phase@1966_3.traverse at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_bottomup_phase.svh:61
7: function worklib.uvm_pkg::uvm_bottomup_phase@1966_3.traverse at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_bottomup_phase.svh:61
8: function worklib.uvm_pkg::uvm_bottomup_phase@1966_3.traverse at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_bottomup_phase.svh:61
9: task worklib.uvm_pkg::uvm_phase@2082_4.execute_phase at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_phase.svh:1208
10: process in worklib.uvm_pkg::uvm_phase::m_iterate_through_phases at /vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_phase.svh:1983
/vl/edatools/extern/Cadence/INCISIV/11.1/001-p/tools/uvm/uvm_lib/uvm_sv/sv/base/uvm_object.svh:901 printer.print_object(get_name(), this);
otherwise while commented everything works fine…can anybody please tell me the reason…
Hi pravin_tavagad,
Can you tell me that, print is a task or function in driver? If print is a function in driver, then problem will not be occur. If print is a task in driver, then problem will occur. You cannot call task in function. Please check your print code in your driver.
Thanks & regards,
Sudheer.
In reply to sudheer:
Hi sudheer,
here print is the default method provided by uvm_driver…I dont have any function/task print () in my driver…
I guess your agent is not configured as UVM_ACTIVE and the driver is not created.
Thus you get the NULL pointer error when you try to access the print() method of the driver.
Change your code to
      driver.print();
In reply to msummer:
hi msummer,
Now its working fine…
thanks and regs,
Pravin
