Not receiving read data in monitor from the DUT for I2C protocol
Getting DATA MISMATCHED in scoreboard :
UVM_INFO testbench.sv(209) @ 310: uvm_test_top.e.a.d [DRV] mode:readd:: addr:1, wdata:22, rdata:x
UVM_INFO testbench.sv(355) @ 330: uvm_test_top.e.a.m [MON] DATA READ:: addr:1, data:x
UVM_INFO testbench.sv(407) @ 330: uvm_test_top.e.s [SCO] DATA MISMATCHED
The data value in monitor is ‘x’, that means monitor is not able to receive data from the DUT to read.
The link for the code on the eda playground : my_i2C_debug - EDA Playground
here is my monitor code:
class monitor extends uvm_monitor;
`uvm_component_utils(monitor)
transaction tr;
uvm_analysis_port#(transaction) send;
virtual i2c_i vif;
function new(string path="monitor",uvm_component parent=null);
  super.new(path,parent);
  super.build_phase(phase);
  tr=transaction::type_id::create("tr");
  send=new("send",this);
  if(!uvm_config_db#(virtual i2c_i)::get(this,"","vif",vif))
     `uvm_error("MON","NOT ABLE TO MONITOR");
  forever begin
 @(posedge vif.clk);
   if(vif.rst)
    tr.md = rstdata;
    `uvm_info("MON", "SYSTEM RESET DETECTED", UVM_NONE);
    send.write(tr);
    else begin
      if(   vif.wr)
      tr.md     = writed;
      tr.wr     = 1;
      tr.din    = vif.din;
      tr.addr   =  vif.addr;
         `uvm_info("MON", $sformatf("DATA WRITE:: addr:%0d w_data:%0d",tr.addr,tr.din), UVM_NONE);
      send.write(tr);
      else if (   !vif.wr )
      tr.md     = readd;
      tr.addr  =  vif.addr;
       tr.wr   = 0;
       vif.done=1;
       tr.din  = vif.din;
       tr.datard = vif.datard;
       `uvm_info("MON", $sformatf("DATA READ:: addr:%0d, data:%0d",tr.addr, tr.datard), UVM_NONE);
      send.write(tr);
In reply to gliese_581e:
You have a lot of errors, but here are some hints to help you:
For outputs from your DUT, you want to use a wire in your interface, not logic.
On EDA Playground, run your test with the other simulators as sometimes a simulator will accept non-compliant code and mask logic errors.
In reply to cgales:
yeah it’s showing many syntax errors with aldec simuator but no syntax erros with synopsys vcs, is that what you are referring to ?
