Not able to Configure
Hi Frds,
I did UVM verification environment of FIFO. But I got the fatal message “Not able to Configure” while running.
AGENT
local wrapper wiff;
local virtual intf intf_01;
  super.connect_phase(phase);
   if(!get_config_object ("wiff",obj,0))
  `uvm_fatal(get_type_name(),"Not able to configure");
   else begin
   if(!$cast(wiff , obj))
     `uvm_fatal(get_type_name(),"Object is not correct type");
    intf_01 = wiff.intf_01;
    if(is_active == UVM_ACTIVE)
       driver.seq_item_port.connect(sequencer.seq_item_export);
    driver.intf_0 = wiff.intf_01;
TOP
wrapper wif;
  wif = new();
  wif.set_wrapper(intf_01);
  set_config_object("uvm_test_top.env.ag1", "wrapper", wif,0);
// uvm_config_db # (wrapper)::set(null,"uvm_test_top.env.ag1" , "wiff",wif) ;
 run_test("base_test");
 #200; $finish;
 // #2000 global_stop_request;
Please guide me to solve this issue.
Thanks & Regards,
P.Masilamani Raja
You are setting “wrapper” and getting “wiff”
Also look at the path reported by `uvm_fatal and make sure it matches that you used to set_config.
Hi
Thanks for your reply.
I have tried with “wiff” instead of wrapper, that time also got same error.
I got the error message in agent module. Agent code for your reference.
uvm_object obj;
local wrapper wiff;
 fifo_driver driver;
 fifo_sequencer sequencer;
protected uvm_active_passive_enum is_active ;
 function new (string name = "tc_fifo_agent", uvm_component parent = null);
  super.new(name , parent);
int is_active_val = 0;
  super.build_phase(phase);
if(!get_config_int ("is_active", is_active_val))
  this.is_active = uvm_active_passive_enum'(is_active_val);
     driver = fifo_driver::type_id::create("driver",this);
     sequencer = fifo_sequencer::type_id::create("sequencer",this);
   else begin
Please guide me.
In reply to MasilamaniRaja:
Can you show the complete error message?
Hi ,
UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(215) @ 0: reporter [Questa UVM] QUESTA_UVM-1.2
UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(217) @ 0: reporter [Questa UVM] questa_uvm::init(+struct)
UVM_INFO @ 0: reporter [RNTST] Running test base_test…
********* Initialized values at Reset *********
UVM_INFO @ 0: uvm_test_top.env [uvm_test_top.env] Build
UVM_FATAL ../testbench/fifo_agent.sv(45) @ 0: tc_fifo_agent [uvm_agent] Not able to configure
— UVM Report Summary —
** Report counts by severity
UVM_INFO : 4
UVM_WARNING : 0
UVM_ERROR : 0
UVM_FATAL : 1
** Report counts by id
[Questa UVM] 2
[RNTST] 1
[uvm_agent] 1
[uvm_test_top.env] 1
** Note: $finish : /tools/questa10.1a/questa_sim/linux/../verilog_src/uvm-1.1a/src/base/uvm_report_object.svh(277)
Time: 0 ns Iteration: 16 Region: /uvm_pkg::uvm_phase::m_run_phases
1
Break in Function uvm_pkg/uvm_report_object::die at /tools/questa10.1a/questa_sim/linux/../verilog_src/uvm-1.1a/src/base/uvm_report_object.svh line 277
The error message shows that it is generated from path “tc_fifo_agent”, yet you are setting the path "“uvm_test_top.env.ag1”.
Can you explain why the agent is not part of any hierarchy? Maybe you need to show the code that creates the hierarchy.
Hi
I have set the path as “uvm_test_top.env.ag1” only. Here for your reference.
set_config_object(“uvm_test_top.env.ag1”, “wiff”, wif,0);
I have created the object for agent in environment module. So I have set the hierarchy path of agent in top module.
Environment code:
class tc_fifo_env extends uvm_env;
`uvm_component_utils(tc_fifo_env)
  tc_fifo_agent ag1;
function new(string name = "tc_fifo_env", uvm_component parent = null);
        super.new(name, parent);
        ag1 = new();
        uvm_report_info(get_full_name(),"Build", UVM_LOW);
        ag1 = tc_fifo_agent::type_id::create("ag1",this);
Testcase
class parent_test extends uvm_test;
virtual intf intf_0;
  tc_fifo_env env;
`uvm_component_utils(parent_test)
function new (string name = "parent_test" , uvm_component parent = null);
//  env = new ("env" , this);
  uvm_top.print_topology();
     env = tc_fifo_env::type_id::create("env",this);
   set_config_int("env.ag1","is_active" ,0);
Hi ,
I have used uvm_config_db instead of set_config_* and get_config_* the fatal error is gone now.
Now I got another fatal message is
" UVM_FATAL @ 0: reporter@@seq01 [SEQ] neither the item’s sequencer nor dedicated sequencer has been supplied to start item in seq01 ".
In my agent file I have set uvm_active_passive_enum is_active = UVM_ACTIVE. But I have seen the output factory its showing UVM_PASSIVE.
Please help me.
Thanks & Regards,
P.Masilamani Raja
Hi
I got the Illegal virtual interface dereference in my monitor module.
Monitor:
class fifo_monitor extends uvm_monitor;
protected virtual interface intf intf_m;
protected tc_instruction txn_collect;
`uvm_component_utils (fifo_monitor)
function new (string name = “fifo_monitor” , uvm_component parent = null);
txn_collect = new();
function void assign_vi (
virtual interface intf intf_1 );
intf_m = intf_1;
task run ();
collect_txn();
join
virtual protected task collect_txn();
forever
@(intf_m.cb);
case (intf_m.read_write_control)
1’b1: txn_collect.rd_wr = WR;
1’b0: txn_collect.rd_wr = RD;
endcase
  @(intf_m.cb);
  txn_collect.data_in = intf_m.data_out;
“cb” is modport name.
clocking cb @(posedge clock);
output read_write_control,reset;
output data_in;
input data_out,full,empty;
endclocking
modport dut (input read_write_control,reset,data_in ,output full,empty,data_out);
modport tb (clocking cb);
Please help to resolve this issue.
you ave ag1 = new() and later have create method. is it a typo?
No…, First i have created the handle (ag1 = new ()) after that only created the method.
Hi
I have tried to force consecutive WR / RD operation in my sequence.
But I am getting the error message.
../tests/sequence.sv(20): randomize() failed due to conflicts between the following constraints:
../tests/sequence.sv(20): 1’h0;
UVM_WARNING ../tests/sequence.sv(20) @ 25: uvm_test_top.env.ag1.sequencer@@seq01 [RNDFLD] Randomization failed in uvm_do_with action
Sequence:
tc_instruction pkt; ---------- > Transaction file name
virtual task body();
repeat(10) begin
uvm_do_with ( pkt , { pkt.rd_wr == WR ; pkt.data_in == data_in;} ) uvm_do_with ( pkt , { pkt.rd_wr == RD ;} ) ---------------- Line no : 20
Please help me ASAP.
