I am trying to run a switch project(WWW.TESTBENCH.IN - Easy Labs : UVM). As it is an old version, I made some changes to remove deprecated errors.
Modified code is in (1) - EDA Playground
Now I don’t see data flow in receiver from output interface, whereas I can see details in waveform.
can someone help me what am I doing wrong
how do we connect interface array(interface if[4]) to any component array(Monitor mon[4]) and how do we use interface in monitor after connecting
In reply to vennela.adavelly:
I do not understand your complains. It works in my environment and I see the pinlevel interfaces toggeling after doing a few changes:
(1) remove the $finish in your testbench file
(2) replace the forever loops in your sequence. If there is a forever the simulation will never stop.
But I see many errors.
And there are more errors inside. You are using clocking blocks but synchronizing on the clock edge instead. This might cause more serious errors.
